Missing 'Update Record' Server Behaviour panel
Thread begun 7/20/2010 5:19 pm by jebrandon343719 | Last modified 7/22/2010 1:29 pm by jebrandon343719 | 3129 views | 6 replies |
jebrandon343719
I created pages with DataAssist wizzard a few months ago. Now when I open my Update page, the behaviour for Update record is missing in my server behaviour panel. I need to make changes, but cannot!
The Update code is present and unchanged in my page.
How do I get this to re-appear??
Dani Chankhour
Can you please send me your page so i can test it on my end to see if i can see the Update Server Behavior.
If the code have not changed, it could be that you have a different version of DA installed or that DA is not installed any more.
jebrandon343719
Upgraded to CS5 and latest DA version
I have upgraded to CS5 and installed the latest version of DataAssist.
The code is attached
Dani Chankhour
it looks like the Server Behavior was slightly modified which is why it was not recognized as a server behavior. I have made the necessary changes and attached the updated file. you can see the small changes on line 66 and 74.
make sure to create a backup of you current file.
jebrandon343719
That worked
Hi Dani,
Thanks for fixing that. It works.
Can you explain what was wrong?
Dani Chankhour
The server behavior has to be in certain format in order for DW to recognize it. In your case there was two new line characters that were removed which is why the Server behavior was not showing.
jebrandon343719
Thanks Dani
