CSS Menu Writer not function in IE 6.0
Thread begun 7/20/2010 7:01 am by davidarnett2008352565 | Last modified 7/23/2010 1:08 pm by Jason Byrnes | 2016 views | 3 replies |
I purchased CSS Menu Writer Vs 2.0.5 and installed it with no problems. When I posted the menu at www.spectrumdothan.org it works fine in Safari, FireFox and IE 7+.
The menu does not function properly in IE 6.0 which according to the documentation it should. It shoves 3-4 of the menu items down below the others. Am I missing something? Any help with this would be much appreciated; otherwise, I will need to find another solution to my simple horizontal menu.
Thank you!
davidarnett2008@gmail.com
David
find the following:
<!--[if lte IE 6]>
<style type="text/css" media="all">
@import url("../CSSMenuWriter/cssmw/menu_ie.css");
</style>
<![endif]-->
and change it to:
<!--[if lte IE 6]>
@import url("CSSMenuWriter/cssmw/menu_ie.css");
</style>
<![endif]-->
Thanks!
Thanks so much...that worked perfectly!
you're welcome.
