Power Gallery NO IMAGES found in Frontend
Thread began 7/20/2010 5:54 am by info345621 | Last modified 7/27/2010 7:03 am by Jason Byrnes | 2826 views | 9 replies |
info345621
I have gallery running and it works as expected but I cannot find any pictures in the one of the gallery.
All pictures are correctly stored in the database. I can add pictures and they are shown in the administration area. But no pictures are shown in the public area ...
Link:
cuero.php
The rest of the galleries work fine.
I have added the following code at line 1 in this page:
error_reporting(E_ALL);
But no PHP errors being reported.
Please I need to solve the problem asap!!
I find in the forum similar posts with this problem but, no solution appear!
Thank You!
It looks like you may have sorted out the issue you were experiencing. When I view your site I can see the image where you had the text 'no image' before. Was there something specific that you needed to adjust to get it working?
info345621
Hi Eric,
The only way I found to functional this gallery was removing it and make the same gallery again. There no error in the code of my pages, The Gallery disappeared after that added new images where the size was approximately 4 MB so I think this could be the problem.
Is there a limit of weight or number of photos?
Thanks also for the support!!!
login.php
Fernando Tuzzi
Okay, I delete the old gallery and load this again at this poin all work fine, but when I fill the photo description in the frontend appear the message NO IMAGES the rest of gallerys without description works, I think that the problem appear when I fill the pictures information.
Here the problematic links:
cuero.php
tela.php
And heare the working links without description:
vinchas.php
mini.php
Please I need to solve the problem urgent!!
Thanks!
please update the ticket I created for you with contact information so an engineer can look into the issue with you.
login.php
Fernando Tuzzi
Hi, my contact information is up to date, if you need any other information let me know.
Other Problem are the special characters for spanish language in the picture descrition like ñ, á, etc.
I have looked at other post but I have not found the solution to this problem.
Many are the problems with Power Gallery, I'm not a beta tester, and I am losing time with this topic. I need a specific and definitive solution to these problems or otherwise I shall be obliged to claim a refund of money paid for this Pre-built PHP Solution.
Thanks!
In the backend ticket I have created for you, i do not see any of your contact information.
I have edited the backend ticket requesting that you provide your phone number so one of our engineers can get in contact with you. We will be able to work with you over the phone to find the cause of the issue and fix the problem.
Fernando Tuzzi
You have my Skype and my MSN, but if you need more information please send me a private message or send me an email support where I can send you all the information you need to fix this problem.
Thanks!
the support ticket I created for you is a private ticket where you cvan provide those details.
You will need to go to your support history:
and update the private support ticket with your contact information. Once you have updated the private support ticket in the your support history with this information, an engineer will be able to contact you to resolve the issue.
