installation problem
Thread begun 7/19/2010 10:40 am by lorgain396837 | Last modified 7/19/2010 1:49 pm by Jason Byrnes | 1742 views | 3 replies |
lorgain396837
I edited the site using a test server and tried to upload the to the remote server and I am getting this error message "Fatal error: Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2) in /homepages/10/d330256273/htdocs/Connections/PowerStoreConnection.php on line 9"
Help Please
the installation routine needs to be completed on the remote server to create the database and the connection with the correct details
In the connections folder on the remote host, delete the installed.txt file, then browse to the power store files on the remote server to start the installation process.
lorgain396837
thanks
That worked... thanks
you're welcome.
