Main Menu Level - Different Backgrounds?
Thread begun 7/18/2010 7:54 am by elevy388997 | Last modified 7/29/2010 10:52 am by Jason Byrnes | 7433 views | 21 replies |
elevy388997Beta Tester
I am trying to make a custom menu in CSS Menu Writer for my dwt but wish to have different background images for each button. I will then take this menu and use it as a preset in site sculptor.
To show you in context, here is the website I am moving over to site sculptor CMS so the client can change information themselves:
AboutUs.html
The navigation is vertical and requires different colors for each one. How can I accomplish this since the CSS menu writer only does it by level and not each item?
Here is the CSSMenuWriter/cssmw_content/menu.CSS:
"ul#cssmw_content {
cursor: default;
list-style-type: none;
margin: 0 0 0 0;
padding: 0 0 0 0;
width: 0;
ul#cssmw_content ul {
cursor: default;
font-size: 0;
margin: 0 0 0 0;
padding: 0 0 0 0;
ul#cssmw_content ul li {
background-image: none;
ul#cssmw_content li {
padding: 0 0 0 0;
position: relative;
white-space: nowrap;
z-index: 100;
ul#cssmw_content li ul {
display: none;
top: 0;
ul#cssmw_content li:hover > ul {
display: block;
position: absolute;
ul#cssmw_content li.hover > ul {
display: block;
position: absolute;
ul#cssmw_content li.current > ul {
position: absolute;
ul#cssmw_content > li {
ul#cssmw_content > li > a, ul#cssmw_content > li > a:link {
background-image: url("../cssmw_content_images/AboutUs.png");
border-bottom-color: #fff;
border-bottom-width: 1px;
border-right-color: #fff;
border-right-width: 1px;
color: #173232;
display: block;
font-family: "Trebuchet MS", Helvetica, sans-serif;
font-size: 10px;
font-style: normal;
font-weight: bold;
height: 125px;
margin: 0 0 0 0;
padding: 0px 0px 0px 0px;
text-decoration: none;
text-transform: uppercase;
width: 150px;
outline-style: none;
ul#cssmw_content > li > a:active, ul#cssmw_content > li > a:focus {
background-color: #EBEBEB;
color: #173232;
font-weight: bold;
ul#cssmw_content > li:hover > a, ul#cssmw_content > li:hover > a:link {
color: #173232;
font-weight: bold;
ul#cssmw_content > li.hover > a, ul#cssmw_content > li.hover > a:link {
color: #173232;
font-weight: bold;
ul#cssmw_content > li.current > a.current, ul#cssmw_content > li.current > a.current:link {
color: #173232;
font-weight: bold;
This cannot be accomplished in the menu.css file, you need add an inline style to the top level menu elements. For example, the top level menu item may be:
<li><a href="home.html">Home</a></li>
to give that item a unique background color, add an inline style to the anchor:
<li><a href="home.html" style="background-color:red;">Home</a></li>
Ok, so in the menu.php such as:
<li><a href="<?php echo($assumedRoot); ?>about.php" style="background-image:url(../cssmw_content_images/AboutUs.png)"></a></li>
I changed all my navigation links to this and they are all missing. Also, I don't want text that is why there is no label.
there has to be something for the a tag, try this instead:
<li><a href="<?php echo($assumedRoot); ?>about.php" style="background-image:url(../cssmw_content_images/AboutUs.png)">&nbsp;</a></li>
if you are still having a problem send a link where i can investigate the cause.
hmm, still not working. The thing is there was an image before, it just made ALL links that same image. Which is where I got the idea to try and add code to the menu.css.
The website is live but currently doesn't have CMS, so I am trying to do everything locally which may be causing a problem.
I am contacting the client now to let them know I am taking the site down to put up this CMS one. Make things a bit easier for me since I never have luck working locally.
it is possible the path to the image needs to be adjusted. if you post a link, I can look into the issue further.
Another thing, all my other sites with CMS have worked fine but on uploading of this one, it says i need php5 or higher and the permissions need looked at. I haven't changed anything. I deleted all files from remote server and it still is saying i need things.
I contacted my hosting provider and they say, confirming what i though, that it has the most recent php package and there are no restrictions on my file permissions. So something in the code is preventing me from proceeding.
This is what I get:
PHP 4.4.7
PHP 5 or greater is required. Contact your hosting provider to upgrade your PHP server.
GD Image Library
GD Image Library [bundled (2.0.28 compatible)] is installed.
File Permissions
Files and directories cannot be created. Verify the Site Sculptor directory has write permissions on your server.
create a new php file, name it phpinfo.php and add the following code:
<?php phpinfo(); ?>
Then upload this to your server and post back the link.
So my dumb self forgot to change my dreamweaver settings for my new server...so I am uploading everything to the new site and I will let you know when it is up. Locally testing, the css menu writer still is blank when I put in the code for style background images.
please let me know when you can provide a link.
