Thread begun 7/15/2010 12:14 pm by bjgarner241692 | Last modified 7/19/2010 9:05 am by Jason Byrnes | 2868 views | 5 replies |
bjgarner241692
Why does DFP add the extension .jpg to my file when I upload it.
I am uploading a file that is to be renamed to the existing value in the database and overwrite the existing file, in this case, athlete2.jpg. What I get, is a new file called athlete2.jpg.jpg.
I am using the version which supports asp.
please send a copy of the page so I can examine the code.
bjgarner241692
as requested - correction. i am using DFP 2.0.3
Try changing line 59:
'FileName' => "".(str_replace('"', '"', $row_WADAstore_meals['Cost']))  ."",
'FileName' => "".(str_replace('"', '"', substr($row_WADAstore_meals['Cost'], 0, -4)))  ."",
also change line 73:
'FileName' => "".(str_replace('"', '"', $row_WADAstore_meals['zWhere']))  ."",
'FileName' => "".(str_replace('"', '"', substr($row_WADAstore_meals['zWhere'], 0, -4)))  ."",
bjgarner241692
Will this be fixed so that the correct code is entered in the first place?
Yes, I have logged this as a bug.
