Email and display on thankyou page
Thread began 7/15/2010 11:07 am by edwardl.brown311835 | Last modified 7/16/2010 8:14 am by Jason Byrnes | 1312 views | 3 replies |
edwardl.brown311835
Need help...I have a form with many additional form fields...if I fill out the form everything gets sent via email...GREAT!
Now, when I set the action to thankyou.php and echo all of the values from the form...I get everything that was put into the form fields...but no email...
Can I have my cake and eat it too?
Is there a way to have the form submit to thankyou.php so the user can see the information they put in...and I get an email with the same...?
Really would appreciate help with this, thanks!
No, it is not supported in the contact form solution pack to display the entered information on the thank you page.
edwardl.brown311835
...just to be clear
Thanks Jason,
I just want to make sure I get it...even though it's not supported, I have displayed the form information on the thankyou page...
but are you saying there is no way to have the form submit to thankyou.php and send an email...is there a work-around?
...and don't say no...even if the answer is no :-)
you could add the following code at the top of the contact page:
if($_SERVER['REQUEST_METHOD'] == "POST") {
    foreach(
$_POST as $key=>$val) {
$_SESSION[$key] = $val;
this will store the form values in session variables, then on the thank you page, you can use the session variables to output the information submitted by the form:
<?php echo((isset($_SESSION["Contact_Name"]))?$_SESSION["Contact_Name"]:""?>
