Passing GET variables to <iframe>
Thread begun 7/15/2010 7:51 am by tom92909 | Last modified 7/19/2010 11:15 am by Jason Byrnes | 3180 views | 3 replies |
tom92909Beta Tester
I'm having trouble passing a variable to (3) <iframes> on an action page.
Example:
<table>
  <?php do { ?>
    <tr>
     <td><INPUT TYPE="BUTTON" VALUE="<?php echo $row_getData['id']; ?>" ONCLICK="window.location.href='my_iframe_page.php?id=<?php echo $row_getData['id']; ?>'"></td>
    </tr>
    <?php } while ($row_getData = mysql_fetch_assoc($getData)); ?>
</table>
Below are the <iframes> that are part of my_iframe_page.php
<div align="center">
<p>
   <iframe  src="page1.php?id=<?php echo "".$_GET['id']."";?>"></iframe>
</p>
<p>
   <iframe  src="page2.php?id=<?php echo "".$_GET['id']."";?>"></iframe>
</p>
<p>
   <iframe  src="page3.php?id=<?php echo "".$_GET['id']."";?>"></iframe>
</p>
</div>
How do I pass this ID to all three <iframes>? Is this the correct way to go about doing this?
Should I use a POST instead?
I have also attempted to echo and use the following with no success in the <iframe>, but I am able to successfully echo it on the page with no issue.
<?php $recid = urldecode($_GET['id']); ?>
Thanks!
that code should work, do you have a link where I could see the problem to get a better idea of what is wrong?
tom92909Beta Tester
The page(s) that I'm working on are on a client site behind a secure directory. I have created a few screen shots and grouped them up to illustrate the output.
I hope this will suffice. As you can see I'm now trying to use a $session variables to transfer the record information to the pages. The GET was giving me empty results as well.
Thanks!
login.php
