CSS Form Builder NOT Reentrant
Thread begun 7/14/2010 8:57 am by jonm145238 | Last modified 7/14/2010 7:12 pm by Jimmy Wu | 2573 views | 3 replies |
jonm145238
Ok, the advertisement said that CSS Form Builder is reentrant but apparently this is not the case, or at least I can not figure out how to get back in after I have closed and reloaded a document. The problem is that I have had to make some formatting changes that I really want to be consistent from form to form.
It is looking like I will need to modify my pages manually. Normally I would have no problem with this but I am under such tight time constraints. I have found little helpful documentation at all regarding this product.
Jimmy Wu
Form builder is re-entrant. You want to mouse over the form, and at the top, there should be a label that starts with CSS Form Builder. Click on that label and there should be some edit buttons that show up in the properties inspector. If it doesn't show up, you can try clicking somewhere on the page that isn't in the form and clicking on the label again.
jonm145238
This is what I had been looking for all along but was never able to find it. I assume this is not possible from the code view? From the Design view it took a while to get the exact spot because of teh layout of my template but I did find it. This is workable but very obnoxious. I should be able to do this easily from the code view.
Thanks for your help, you have saved me a great deal of grief.
Jimmy Wu
Currently there isn't a way to re-enter the form from the code view. I apologize for the inconvenience this has caused.
