Universal email and Data Assist Results page
Thread begun 7/14/2010 8:31 am by sunshine64231 | Last modified 7/14/2010 1:27 pm by Jason Byrnes | 2227 views | 3 replies |
sunshine64231
I have created a search and results page in data assist and applied universal email to the results page. When I user the search page and click submit I am directed to the success page I previously set up but no email is sent.
Before I applied universal email to the results page I made sure it actually did show the results of the search so I do not believe that is the problem.
What should I check to determine why no email is being sent? (The universal email program is working in other parts of this same site so I believe it is something involving the results page) (I am using the current versions of all your extentions)
Appreciate your help
The most likely culprit is the trigger.
You should select the any Form Post trigger, make sure not to select the Currant page Submit trigger.
if you are still having difficulties, please send a copy of your page so I can examnie the code.
sunshine64231
Found the problem
Thanks Jason
I think I found the problem. I should have selected RECORDSET LOOP from the TO button.
Ok, glad to hear you have it working.
