Slideshow Dissolve Height Problem
Thread begun 7/14/2010 5:25 am by blair404107 | Last modified 7/19/2010 12:03 pm by Eric Mittman | 2362 views | 3 replies |
blair404107
I have had a look at some of your other threads to do with resizing the main gallery image but have had no success with adjusting the height of the Slideshow Dissolve main image. I have added a new array to the 'properties.php' file and have changed the size to the new array setting in the 'index.php' file. I have logged into the Admin, Settings and selected 'Update Watermark' as instructed. The thumbnail images (.pg-sd-thumbnails) are also placed above the text overlay (.pg-sd-captions) and I think this may be causing the main image to be cropped on the top and bottom. Also the page is not fully downloading. I have spent many hours on this. Can you help me please.
Justin Nemeth
Can you send me a link to your gallery? Also, what is the new size you are trying to use so I can compare that to what your link is doing?
It should be as simple as what you already did. Basically, the slideshow should detect the size of the large image and adjust itself accordingly, but it sounds like that is not happening for some reason.
blair404107
Hi Justin,
Thanks so much for getting back to me. Can I email the link to you privately please?
I have opened a ticket for you so information can be exchanged in private. To update your ticket login and visit your support history.
