Sub menu horizontal alignment
Thread begun 7/13/2010 10:56 pm by chijo410927 | Last modified 7/16/2010 12:01 pm by Eric Mittman | 3150 views | 5 replies |
chijo410927
I'm having issues properly aligning my third level menu boxes.
URL: testsite/
Mouseover the "Services" top-level nav item. Then mouseover the 2nd level sub menu item "Spay and Neuter Packages." Notice how the 3rd level sub menu item overlaps the 2nd level boxes.
How do I control this alignment?
Thanks much.
Jimmy Wu
In your menu.css file, find this block of css:
ul#cssmw1 ul.level-2 > li > a, ul#cssmw1 ul.level-2 > li > a:link {
You would want to change the margin: 0; to this:
margin:0 0 0 45px;
So the end result is:
background-color:#517595;
background-image:none;
border-bottom:1px solid #FFFFFF;
border-right:1px solid #FFFFFF;
color:#FFFFFF;
display:block;
font-family:"Trebuchet MS",Helvetica,sans-serif;
font-size:12px;
font-style:normal;
font-weight:bold;
margin:0 0 0 45px;
outline-style:none;
padding:5px 10px;
text-decoration:none;
text-transform:none;
width:auto;
chijo410927
Perfect, that works. Thanks so much for the reply and advice.
Question for the future...
Why the 45px margin specifically? I have the width of the first sub level set to auto.
The 45px represents the amount of overlap that was occurring with the other element, you are essentially just saying to start out 45px from the left of where it would normally start.
chijo410927
Thank you for your reply.
Yes, I understand the CSS margin and that it will be 45px. My question was how you knew that 45px would do the trick? I don't have my sub menu set to a set width of 90px. If that were the case, I would have seen that my 3rd level menu was starting in the middle and I would have guessed that 45px might have worked.
How did you arrive at the 45px number? Is this "magic" number to use for the left margin with setting the first sub level to auto width?
thanks
I did not personally discover the 45px value, but when a specific value like this is mentioned it is usually the result of some css debugging done with a tool like Firebug for FireFox. This is a terrific tool that will allow you to inspect objects and page parts on the fly and make adjustments to them. Normally when I see a css issue like this it is the first thing that I will try. I inspect the element then I look at the css that is involved and start making adjustments.
