Error message - new version won't upload image file
Thread begun 7/13/2010 5:38 pm by LWag48648773 | Last modified 7/15/2010 5:38 pm by Jason Byrnes | 4847 views | 9 replies |
LWag48648773
Can you tell me why I keep getting this message?
The Upload Files_WA script does not define the findServerBehaviors function.
Since I downloaded the latest version, I have not been able to get the image file to upload. I have been working on this about 20 hours. Everything is working except the file is not uploading. I mean my code is ok, the path is good.
I have this working on another site and I checked that database compared to this and they appear to be setup identical. They are also on the same server.
Is it something with the newer version? The field is a Long Blob. I even added the code that was suggested to someone else in this forum.
ini_set('memory_limit','500M');
I'd really like to get this work. Any advice?
Thank you.
for the error message you are getting, try deleting the Dreamweaver cache file from the users configuration folder:
Please send a copy of the upload page so i can examine the code to determine what the problem may be.
LWag48648773
I have attached a screenshot of the database with a few items I entered. As you can see, the blog is showing a value so it knows something should be there. Also, if I tell it to upload an image that is already in the CatImages folder, the image will display. Obviously it is not uploading it but the code is correct because it knows where to find the image. Notice the item in the middle of the ones with the goofy names. The description field says 'this one was in the folder'.
The image field is a Longblog in the database. I have everything set just like the database for the other web site where I am using this. I removed some of the table rows in the code to make this file smaller.
I also deleted the file as instructed in your last message.
Thank you,
Laura
Digital File pro does not support storing the image into a blob field.
With digital file pro, you can upload the file to a folder on the server, then store the file name in a text column in the database, but it does not support storing the image itself in a blob field of the database.
LWag48648773
I have a longblog in my other database that works just with DFP. I changed it to text and the code is working and the database is recognizing all my images, but still no files are actually uploading to the server.
I realized I forgot to send you the code.
<?php require_once("Connections/connFay.php"); ?>
<?php require_once("WA_DataAssist/WA_AppBuilder_PHP.php"); ?>
<?php require_once("WA_DigitalFilePro/HelperPHP.php"); ?>
<?php require_once( "WA_SecurityAssist/Helper_PHP.php" ); ?>
if (!WA_Auth_RulePasses("Logged in to Admin")){
WA_Auth_RestrictAccess("Admin_LogIn.php");
// WA_UploadResult2 Params Start
$WA_UploadResult2_Params = array();
// WA_UploadResult2_1 Start
$WA_UploadResult2_Params["WA_UploadResult2_1"] = array(
'UploadFolder' => "CatImages/",
'FileName' => "".$WA_DFP_UploadStatus["WA_UploadResult2"]["serverFileName"] ."",
'DefaultFileName' => "",
'ResizeType' => "2",
'ResizeWidth' => "250",
'ResizeHeight' => "120",
'ResizeFillColor' => "#FFFFFF" );
// WA_UploadResult2_1 End
// WA_UploadResult2 Params End
WA_DFP_SetupUploadStatusStruct("WA_UploadResult2");
if(isset($_POST["Insert_x"])){
WA_DFP_UploadFiles("WA_UploadResult2", "Image", "2", "[NewFileName]_[Increment]", "true", $WA_UploadResult2_Params);
// WA Application Builder Insert
if (isset($_POST["Insert_x"])) // Trigger
$WA_connection = $connFay;
$WA_table = "Catalog";
$WA_sessionName = "WADA_Insert_Catalog";
$WA_redirectURL = "Catalog_Insert.php";
$WA_keepQueryString = false;
$WA_indexField = "ItemID";
$WA_fieldNamesStr = "CatalogID|ItemName|Description|Price|Age|Category|Image";
$WA_fieldValuesStr = "".((isset($_POST["CatalogID"]))?$_POST["CatalogID"]:"") ."" . "|" . "".((isset($_POST["ItemName"]))?$_POST["ItemName"]:"") ."" . "|" . "".((isset($_POST["Description"]))?$_POST["Description"]:"") ."" . "|" . "".((isset($_POST["Price"]))?$_POST["Price"]:"") ."" . "|" . "".((isset($_POST["Age"]))?$_POST["Age"]:"") ."" . "|" . "".((isset($_POST["Category"]))?$_POST["Category"]:"") ."" . "|" . "".((isset($_POST["Image"]))?$_POST["Image"]:"") ."";
$WA_columnTypesStr = "',none,''|',none,''|',none,''|none,none,NULL|',none,''|',none,''|',none,''";
$WA_connectionDB = $database_connFay;
$insertParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WA_Sql = "INSERT INTO `" . $WA_table . "` (" . $insertParamsObj->WA_tableValues . ") VALUES (" . $insertParamsObj->WA_dbValues . ")";
$_SESSION[$WA_sessionName] = mysql_insert_id();
if ($WA_redirectURL != "") {
<head>
<title>Insert Catalog</title>
<link href="WA_DataAssist/styles/Refined_Pacifica.css" rel="stylesheet" type="text/css" />
<link href="WA_DataAssist/styles/Arial.css" rel="stylesheet" type="text/css" />
</head>
<body>
<div class="WADAInsertContainer">
<form action="Catalog_Insert.php" method="post" name="WADAInsertForm" id="WADAInsertForm">
<div class="WADAHeader"><h1 align="center">Insert Record</h1></div>
<div class="WADAHorizLine"><img src="WA_DataAssist/images/_tx_.gif" alt="" height="1" width="1" border="0" /></div>
<table class="WADADataTable" cellpadding="0" cellspacing="0" border="0">
<tr>
<th class="WADADataTableHeader">CatalogID:</th>
<td class="WADADataTableCell"><input type="text" name="CatalogID" id="CatalogID" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">ItemName:</th>
<td class="WADADataTableCell"><input type="text" name="ItemName" id="ItemName" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">Description:</th>
<td class="WADADataTableCell"><input type="text" name="Description" id="Description" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">Price:</th>
<td class="WADADataTableCell"><input type="text" name="Price" id="Price" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">Age:</th>
<td class="WADADataTableCell"><input type="text" name="Age" id="Age" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">Category:</th>
<td class="WADADataTableCell"><select name="Category" id="Category" value="" size="1" />
<option> </option>
<option>Active Play</option>
<option>Arts & Crafts</option>
<option>Calico Critters</option>
<option>Construction</option>
<option>Corolle Dolls</option>
<option>Games</option>
<option>Gears</option>
<option>Infants</option>
<option>Music</option>
<option>Play Mobile</option>
<option>Pretend Play</option>
<option>Puzzles</option>
<option>Science</option></td>
</tr>
<tr>
<th class="WADADataTableHeader">Image:</th>
<td class="WADADataTableCell"><input type="file" name="Image" id="Image" value="" size="32" /></td>
</tr>
</table>
<div class="WADAButtonRow">
<table class="WADADataNavButtons" border="0" cellpadding="0" cellspacing="0">
<tr>
<td class="WADADataNavButtonCell" nowrap="nowrap"><input type="image" name="Insert" id="Insert" value="Insert" alt="Insert" src="WA_DataAssist/images/Pacifica/Refined_insert.gif" /></td>
<td class="WADADataNavButtonCell" nowrap="nowrap"><a href="Catalog_Results.php" title="Cancel"><img border="0" name="Cancel" id="Cancel" alt="Cancel" src="WA_DataAssist/images/Pacifica/Refined_cancel.gif" /></a></td>
</tr>
<tr>
<td><h2 align="center">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<a href="Catalog_Search.php">Go to Search Page</a></h2></td></tr>
</table>
<input name="WADAInsertRecordID" type="hidden" id="WADAInsertRecordID" value="" />
</div>
</form>
</div>
</body>
</html>
the code for the file name is not correct
change:
to;
'FileName' => "[FileName]",
also, in the insert record behavior, you must bind the file column to the WA Uploaded Files (File Field Name) -> Server File Name binding instead of the Form binding group that you are currctly using.
Also, for file uplaod to function, your form must be set to use the multipart/form-data encoding type.
Change:
<form action="Catalog_Insert.php" method="post" name="WADAInsertForm" id="WADAInsertForm" enctype="multipart/form-data">
LWag48648773
I realize that I have been messing with this for so long that I have changed things from wrong to right to back to wrong. I had a couple of those things right at one point and didn't realize I had messed them up. What I had failed to realize is the extra code should go in the file field but that is because it's not that way in my other form. I don't understand how my other form is working properly.
I think I did all you said. I NOW have the image uploading but somehow I messed something else up because the info is not going into the database field. The image field is blank so therefore, no image show up on the page. Please check my code again to make sure I have this correct. I only changed the database to make the image field a text rather than a blob. This shouldn't be this difficult!! :-)
thank you!
<head>
</head>
<body>
<tr>
</tr>
<tr>
</tr>
<tr>
</tr>
<tr>
</tr>
<tr>
</tr>
<tr>
<option> </option>
</tr>
<tr>
<td class="WADADataTableCell"><input name="Image" type="file" id="Image" value="<?php echo $WA_DFP_UploadStatus["WA_UploadResult2"]["serverFileName"]; ?>" size="32"/></td>
</tr>
</table>
<tr>
</tr>
<tr>
</table>
</div>
</form>
</div>
</body>
</html>
in the insert record behavior, you must bind the file column to the WA Uploaded Files (File Field Name) -> Server File Name binding instead of the Form binding group that you are currently using.
LWag48648773
FINALLY! Thank you for the help. I wish I had asked sooner. I see now that when I was doing the last step of changing the Insert Behavior, I was choosing the wrong thing which changed the wrong code. And then I was focusing on the wrong code to try to figure out what was wrong. I'm making notes so I won't struggle with this again.
btw - it does work with a blog but I like the text field better because I can actually see the name of the file now.
Thanks much.
you're welcome.
