edit checkout
Thread begun 7/13/2010 1:03 pm by thegilty57719 | Last modified 7/14/2010 2:59 pm by Jimmy Wu | 2438 views | 3 replies |
thegilty57719
edit checkout
I am trying to resurrect an old ecart done with eCart 4.5.0. What I need to do is change the gateway (Auth.net) code. How can I do this or do I need to start from a clean cart??
Jimmy Wu
You could use the same eCart object, but you would have to delete all the checkout pages that were generated by the checkout wizard. The cart page and add to cart buttons should be able to be used from your previous application.
thegilty57719
eCart Checkout
Thanks That was what I was afraid you were going to say
Jimmy Wu
No problem. If you run into any issues with this, please feel free to open a new thread.
