Spacing issue with results page in DA
Thread begun 7/13/2010 10:37 am by elewis93815 | Last modified 7/14/2010 11:05 am by Jason Byrnes | 1803 views | 3 replies |
elewis93815
Hi, I'm trying to remove the spacing between records on my results pages, please advise on how to control or remove the "white" space between records.
I've attached my search and results pages with the WA_DataAssist and WADbSearch files
Erick
Jimmy Wu
Do you have a link to where I can take a look at your hosted pages? It would help me understand what you're trying to do if I could see the pages live.
elewis93815
Spacing Issues
I've just uploaded the files and connected the database, the url is: index.php
Once you're there you'll see a drop down on upper right side of the website that say's "Select Your Search", pick "Search Categories" from the drop down, then click the "Search Categories" (the button on the right), at that point all of the files should be retrieved. If you notice the wide spacing in between each section, this is what I'm trying to control, I would like to reduce this space to to no more than a the space between standard paragraphs.
the space is being added between them due to blank columns in your data base.
you will need to add an if statemetnt around the <tr> code to only display the row if there is a value in that column in the database.
For example, change:
<tr class="<?php echo $WARRT_AltClass1->getClass(true); ?>">
            <td bgcolor="#FFFFFF" class="WADAResultsTableCell"><strong><?php echo $row_WADAnorthstar['line_name1']; ?></strong> <?php echo $row_WADAnorthstar['line_desc1']; ?> <?php echo $row_WADAnorthstar['class1']; ?></td>
          </tr>
<?php if(($row_WADAnorthstar['line_name1'] != "" && $row_WADAnorthstar['line_name1'] != NULL) || ($row_WADAnorthstar['line_desc1'] != "" && $row_WADAnorthstar['line_desc1'] != NULL)) { ?>
          </tr>
<?php ?>
