Validating End Date > Start Date
Thread begun 7/13/2010 9:42 am by dinohorn397192 | Last modified 7/14/2010 2:58 pm by Jimmy Wu | 2432 views | 3 replies |
dinohorn397192
I have two fields in my form that I want to compare, I want to make sure the enddate field as greater than the start date field...
<input type="text" id="startdate" name="startdate" class="inputForm" disabled="disabled" />
<input type="text" id="enddate" name="enddate" class="inputForm" disabled="disabled" />
Is there a way it can be done with "Min Date" option in the Server Validations wizard?
Thanks,
Jimmy Wu
This requires a bit of modification on your part. You will have to change the min date to be changed dynamically based on the first form field. What I would recommend doing is to set some placeholder text into the min date field, so you can tell where in the code you need to make the change. In this example I used "aaaaaaaaaaaaaaa". I have applied date validation on the 2 fields, on the second one I have added the placeholder min date text. The validation code added looks similar to this:
if ($_SERVER["REQUEST_METHOD"] == "POST")  {
$WAFV_Redirect "";
$_SESSION['WAVT_untitled2_264_Errors'] = "";
  if (
$WAFV_Redirect == "")  {
$WAFV_Redirect $_SERVER["PHP_SELF"];
$WAFV_Errors "";
$WAFV_Errors .= WAValidateDT(((isset($_POST["textfield"]))?$_POST["textfield"]:"") . "",true,".*","","",false,".*","","",true,1);
$WAFV_Errors .= WAValidateDT(((isset($_POST["textfield2"]))?$_POST["textfield2"]:"") . "",true,".*","aaaaaaaaaaaaaaa","",false,".*","","",true,2);
  if (
$WAFV_Errors != "")  {
PostResult($WAFV_Redirect,$WAFV_Errors,"untitled2_264");
You would want to make modifications so the code looks like this:
$WAFV_Redirect "test.php";
  if (
$WAFV_Errors "";
$WAFV_Errors .= WAValidateDT(((isset($_POST["textfield2"]))?$_POST["textfield2"]:"") . "",true,".*",((isset($_POST["textfield"]))?$_POST["textfield"]:""),"",false,".*","","",true,2);
  if (
Basically what I have done is to check the value that was posted in the first checkbox and checked it against the one input in the second checkbox. To do this, I have replaced the "aaaaaaaaaaaaaaa" with ((isset($_POST["textfield"]))?$_POST["textfield"]:"")
dinohorn397192
Tricky! It's working now, thanks!
Jimmy Wu
Great to hear it. If you run into any additional issues, feel free to open a new thread.
