Type Mismatch - Universal Email
Thread begun 7/13/2010 7:25 am by bsmith40309 | Last modified 7/16/2010 11:58 am by Eric Mittman | 3189 views | 6 replies |
bsmith40309
I'm using CDOSYS Universal Email on IIS 5.1 with ASP pages. When I submit a form that is supposed to send an email, I get the following error. Any ideas?
The page cannot be displayed
There is a problem with the page you are trying to reach and it cannot be displayed.
Please try the following:
Click the Refresh button, or try again later.
Open the 192.168.254.5 home page, and then look for links to the information you want.
HTTP 500.100 - Internal Server Error - ASP error
Internet Information Services
Technical Information (for support personnel)
Error Type:
Microsoft VBScript runtime (0x800A000D)
Type mismatch: 'WAUE_SetCharset'
/HR/TimeOff/time_off_request.asp, line 82
Browser Type:
Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; WOW64; Trident/4.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; MDDS)
Page:
POST 282 bytes to /HR/TimeOff/time_off_request.asp
POST Data:
TextRequestDate=7%2F13%2F2010&SelReason=Other+%28Explain+Below%29&IDHours1=.01&IDTime1=&IDDate1=12%2F12%2F2000&IDHours2=&IDTime2=&IDDate2=&IDHours3=&IDTime3=&IDDate3=&EDHours1=&EDStart1=&EDEnd1=&EDHou . . .
Time:
Tuesday, July 13, 2010, 9:19:39 AM
More information:
Microsoft Support
Looks like your page is expecting a value of a particular type for a setting and the value that is being referenced does not match that type. What is on line 82 of the page in question? If you can post back with the entire page in a zip archive so that we can take a look at it.
bsmith40309
File Upload
Attached is the file. Line 82 is . . . set WA_MailObject = WAUE_SetCharset(WA_MailObject,"ISO-8859-1")
I'm still looking into this issue. It seems that it is complaining about the charset value itself, but this should be valid. As a test of this you should try to add in a cStr around the value to ensure that it is set to a string like this:
set WA_MailObject = WAUE_SetCharset(WA_MailObject, cStr("ISO-8859-1"))
If the problem is still present after making this update please post back with a copy of the WA_Universal_Email folder from the site root in a zip archive. I will use the files to do some direct side by side comparing.
bsmith40309
Didn't Fix It
I made that code change, but I'm still getting the same error. Attached are the files you requested . . . although I wonder if this is an IIS setting since I simply moved the site to another server (same version of IIS) and it started throwing this error.
bsmith40309
Fixed It
I found out the problem (sort of). The Universal Email files had changed on the development box, but had not been updated on the server. Once I uploaded the Universal Email folder to the server, it started working.
That is great to hear, I'm glad that you got it worked out by uploading the newer file.
