Missing Server Behavior
Thread begun 7/12/2010 10:44 pm by paulshoe379536 | Last modified 7/14/2010 2:35 pm by Jimmy Wu | 2120 views | 4 replies |
paulshoe379536
I have and insert page that was created with DataAssist. The "Insert Record" server behavior is not showing in the installed behavior list although the code is on the page and the page works properly. The problem is, I can't re-open the behavior to make adjustments. How do I restore access to the "Insert Record" behavior? This is happening on more than one page.
It seems like I can get the behavior to redisplay if I remove the dynamic path on "$WA_redirectURL = " A sample below. Should I be using a different syntax?
$WA_redirectURL = "/members/members_Update.php?member_id=".$_SESSION['member_id'];
Jimmy Wu
if you add another ."" after the dynamic code, then the server behavior will inspect correctly. So it would look like this:
$WA_redirectURL = "/members/members_Update.php?member_id=".$_SESSION['member_id']."";
paulshoe379536
I don't know why I'm having so much trouble with these plugins.
Below is my code for the file upload. I am getting the error messages attached and the wizard will not run.
// WA Application Builder Update
if (isset($_POST["Update_x"])) // Trigger
$WA_connection = $cpDVD;
$WA_table = "family_members";
$WA_redirectURL = "/members/admin_members_Detail.php?member_id=".$_SESSION['member_id']."";
$WA_keepQueryString = false;
$WA_indexField = "family_member_id";
$WA_fieldNamesStr = "last_name|first_name|address1|address2|city|state|zip|home_phone|cell_phone|work_phone|email|birthday|groups|hobbies|comments|photo";
$WA_fieldValuesStr = "".((isset($_POST["last_name"]))?$_POST["last_name"]:"") ."" . "|" . "".((isset($_POST["first_name"]))?$_POST["first_name"]:"") ."" . "|" . "".((isset($_POST["address1"]))?$_POST["address1"]:"") ."" . "|" . "".((isset($_POST["address2"]))?$_POST["address2"]:"") ."" . "|" . "".((isset($_POST["city"]))?$_POST["city"]:"") ."" . "|" . "".((isset($_POST["state"]))?$_POST["state"]:"") ."" . "|" . "".((isset($_POST["zip"]))?$_POST["zip"]:"") ."" . "|" . "".((isset($_POST["home_phone"]))?$_POST["home_phone"]:"") ."" . "|" . "".((isset($_POST["cell_phone"]))?$_POST["cell_phone"]:"") ."" . "|" . "".(isset($_POST["work_phone"]))?$_POST["work_phone"]:"") ."" . "|" . "".((isset($_POST["email"]))?$_POST["email"]:"") ."" . "|" . "".((isset($_POST["birthday"]))?$_POST["birthday"]:"") ."" . "|" . "".((isset($_POST["groups"]))?$_POST["groups"]:"") ."" . "|" . "".((isset($_POST["hobbies"]))?$_POST["hobbies"]:"") ."" . "|" . "".((isset($_POST["comments"]))?$_POST["comments"]:"") ."". "|" . "".$WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"] ."";
$WA_columnTypesStr = "',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''";
$WA_comparisonStr = "=|=|=|=|=|=|=|=|=|=|=|=|=|=|=|=";
$WA_where_fieldValuesStr = "".((isset($_POST["WADAUpdateRecordID"]))?$_POST["WADAUpdateRecordID"]:"") ."";
$WA_where_columnTypesStr = "none,none,NULL";
$WA_where_comparisonStr = "=";
$WA_where_fieldNames = explode("|", $WA_indexField);
$WA_where_fieldValues = explode("|", $WA_where_fieldValuesStr);
$WA_where_columns = explode("|", $WA_where_columnTypesStr);
$WA_where_comparisons = explode("|", $WA_where_comparisonStr);
$WA_connectionDB = $database_cpDVD;
$updateParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WhereObj = WA_AB_generateWhereClause($WA_where_fieldNames, $WA_where_columns, $WA_where_fieldValues, $WA_where_comparisons );
$WA_Sql = "UPDATE `" . $WA_table . "` SET " . $updateParamsObj->WA_setValues . " WHERE " . $WhereObj->sqlWhereClause . "";
if ($WA_redirectURL != "") {
paulshoe379536
after making adjustments you suggested for redirect and upload locations, it seems like things are working better now... thanks for the help
Jimmy Wu
Great to hear that it worked out for you. If you run into any additional issues, feel free to open a new thread.
