Proper Syntax for 'UploadFolder' =>
Thread begun 7/12/2010 8:56 pm by paulshoe379536 | Last modified 7/13/2010 11:12 am by Jimmy Wu | 1087 views | 1 replies |
paulshoe379536
What is the proper syntax for the 'UploadFolder' => ? If I use a variable like $_SESSION['location'] the widget puts double quotes around the variable and I get a parse error from PHP when I try to run it. If I manually remove the quotes, the file is uploaded to the proper location but the next time I open the widget it removes my session variable.
Jimmy Wu
Inside the wizard you would want to input something like this into the field:
<?php echo $_SESSION['location']; ?>
You could also accomplish this by clicking on the lightning bolt icon next to the field and selecting the session variable you want to use.
