WA_SHA1Encryption.php MIA
Thread begun 7/12/2010 1:29 pm by htp372188 | Last modified 7/20/2010 7:17 am by Jason Byrnes | 2584 views | 3 replies |
htp372188
Security Assist did not generate this file.
Jimmy Wu
Have you run through SecurityAssist several times and the file never gets generated? If you haven't, try running it again on a blank site to see if it was just that time that the file didn't get generated or if its not generating at all for you?
In the meantime, I will attach the file for you. It should go into the WA_SecurityAssist directory at the root of your site.
asnw0764437428
WA_SHA1Encryption.php is missing
Same here!! SecurityAssist is not generating the WA_SHA1Encryption.php file. I have installed the latest version of SA and just upgraded DA.
Does SA copy the page from the extension folder into the root of your site?, if so, can you tell me where to put the file so it is permanently in place for each time I may use SA etc. for this purpose.
Many thanks
