JS Error Deleted .dat file already
Thread begun 7/12/2010 9:13 am by Richelle | Last modified 7/15/2010 2:52 pm by Eric Mittman | 2261 views | 3 replies |
Richelle
Hello Guys,
I hope you can help I am on a deadline and can't get DataAssist to cooperate. I am getting an onClick in WA_AppBuilder.htm offsets ToNode: Argument Number 2 is invalid.
What I have done so far...
Deleted the .dat file
Restarted
Deleted again.
Got error
Deleted .dat file
Deleted all wa extensions (in case of conflict)
Installed DataAssist Only
checked for .dat file
Got Error
Deleted .dat file
restarted
Got Error
Dreamweaver was closed unless I was trying it out. I am running the most current version of the program.
Any help is appreciated.
Since you have deleted the dat file and still have this problem there might be an issue with the configuration folder. Even though you have uninstalled the extensions the configuration folder may be corrupted and causing some problems for you. Here are the steps that you can take to rename the folder and have DW recreate it for you:
showpost.php?p=12293&postcount=2
If you continue to have this problem please let us know and I will ensure that a ticket is opened up for you on this issue.
Richelle
Update
Still getting error after a clean install of DW. The error is at line 398
Were you able to successfully rename the configuration folder and have DW recreate it? When you re-installed DW did you have to re-install the extension? The type of error you are reporting should be resolved with a new configuration folder and by removing the installed extensions then re-installing them. I just need to confirm that you have done this and are still getting the same result.
