2 Versions of E Cart
Thread begun 7/11/2010 12:21 am by J7HNW | Last modified 7/12/2010 7:07 am by Jason Byrnes | 1381 views | 1 replies |
J7HNW
Please can you clarify something for me
I need to run E Cart 5 for new sites in PHP but still need to maintain older sites written in ASP. I have adobe CS4 Web Design Premium installed on my PC as the main program - running E Cart 5 which I will use always from now onwards. So the main installation is fine.
I know I have to set up a second user as administrator and have done this.
When I log into the new user account - should I
1. Open up the CS4 Web Design version ( Which is already installed under the main user )
and which appears on the start menu for the 2nd user and install E Cart 4. Surely this
would conflict with the main installation under the primary user ?
or
2. I also purchased a Stand Alone Version of Dreamweaver CS4 before I bought the CS4
Web design suite - so should I install this instead under the 2nd user log in and then
install the older version E Cart 4
I am not sure which is the one I should choose.
Thank you
the first option.
Extensions are installed on a per user basis.
The installation of eCart 4 into the new user will not conflict with the eCart 5 installation under the other users account.
