Error message: Unknown column 'test' in 'where clause'
I'm getting the following error when the "registration.php" form is submitted. This form was generated using the Security Assist.
You have a column when filling out the registration form what field are you entering the value "test" into?
You have a column in your database that is a numeric column that the text value "test" is trying to be inserted into.
