SA Pro 1.08
Thread begun 7/10/2010 8:14 am by info242476 | Last modified 7/13/2010 2:07 pm by Eric Mittman | 3034 views | 4 replies |
info242476
SA Pro 1.08
I am having an issue creating a website using SA Pro ver 1.0.8. After using the wizard the site generates. When previewing home page I get: undefined undefined at the top of the page. No text in the body of the page (only header is displaying) nothing aligns with background.
I am using DW CS4 on a windows xp computer.
I have used multiple template styles - this on is open space with a poppy theme.
info242476
Update
I reloaded ver 1.0.7 and still have the problem.
Other posts have similar descriptions. What is the fix? I have a deadline here.
It looks like you are creating a static html site. Do you have a testing server defined in DW? If so how is it setup?
Have you tried clearing the cache file or renaming the configuration folder to see if these things clear up the issue? Please follow the instructions here to see if this resolves the problem for you.
Clearing the cache file
Renaming the config
showpost.php?p=12293&postcount=2
Please let us know if you continue to have this problem and I will ensure that a ticket is opened up for you to look into this further.
info242476
Problem Continues
No change after both.
I do not use a testing server, never have. Yes it is a static site. The text below the header does not display when viewing in any browser or live view.
I have lost 1 client and now one other is on the fence. What do we need to do to get this product useful again?!?
I have opened a ticket for you on this issue so that it can be looked into further. To check the status of your ticket or update it login and visit your support history.
