Error messages upon logging in.
Thread begun 6/03/2009 11:36 am by tim.nealon288075 | Last modified 6/03/2009 12:15 pm by tim.nealon288075 | 3506 views | 3 replies |
tim.nealon288075
I follow the instructions for setting this up.I keep getting these messages after I log-in. Can someone please tell me what they mean and how to fix them.
Thank You
Warning: mysql_select_db(): supplied argument is not a valid MySQL-Link resource in /usr/local/4admin/apache/vhosts/wwaraft.com/httpdocs/cms/admin/index.php on line 42
Warning: mysql_query(): supplied argument is not a valid MySQL-Link resource in /usr/local/4admin/apache/vhosts/wwaraft.com/httpdocs/cms/admin/index.php on line 44
Warning: mysql_select_db(): supplied argument is not a valid MySQL-Link resource in /usr/local/4admin/apache/vhosts/wwaraft.com/httpdocs/cms/admin/contents_results.php on line 98
Warning: mysql_query(): supplied argument is not a valid MySQL-Link resource in /usr/local/4admin/apache/vhosts/wwaraft.com/httpdocs/cms/admin/contents_results.php on line 102
Justin Nemeth
Verify you have the correct MySQL database info in the connections file. Those errors basically mean it can't connect to your database.
tim.nealon288075
Okay, I figured out why it was giving me those messages, only to get these
Warning: main(Connections/localhost.php) [FUNCTION.MAIN]: failed to open stream: No such file or directory in /usr/local/4admin/apache/vhosts/wwaraft.com/httpdocs/index.php on line 1
Warning: main() [FUNCTION.INCLUDE]: Failed opening 'Connections/localhost.php' for inclusion (include_path='.:/usr/local/4admin/apache/lib/php') in /usr/local/4admin/apache/vhosts/wwaraft.com/httpdocs/index.php on line 1
Warning: main(WA_CMS/WA_CMS.php) [FUNCTION.MAIN]: failed to open stream: No such file or directory in /usr/local/4admin/apache/vhosts/wwaraft.com/httpdocs/index.php on line 2
Warning: main() [FUNCTION.INCLUDE]: Failed opening 'WA_CMS/WA_CMS.php' for inclusion (include_path='.:/usr/local/4admin/apache/lib/php') in /usr/local/4admin/apache/vhosts/wwaraft.com/httpdocs/index.php on line 2
This happens after I create a content area and add the code snippets to the page as directed. I view the page and get these errors.
Also, in place of where the content should be, I get this error:
Fatal error: Call to undefined function: wa_getcmscontent() in /usr/local/4admin/apache/vhosts/wwaraft.com/httpdocs/index.php on line 198
Thanks for the help.
tim.nealon288075
Geez, I need to spend one more minute working on these problems after I give up on them. The problem was ...well, I am dumb, blah!
