"untitled untitled" on top of each page.. (Read other threads.. no solution)
Thread begun 7/09/2010 10:58 am by Lee Fuller | Last modified 7/09/2010 3:18 pm by Lee Fuller | 3431 views | 6 replies |
Lee Fuller
Anyone have a solution for this? Each and every page has "undefined undefined" on the top.
1 - Yes.. Local and Testing servers are configured.
2 - Yes.. have uninstalled and reinstalled extensions.
3 - Yes.. have deleted the cache file.
Nothing seems to change it.
Can you post back with a copy of your index page and one of the content pages from the site in a zip archive so that we can take a look at this?
Lee Fuller
Yes.. here you go.
It seems that there might be a problem with the template that you are using as both of these pages are missing the top portions of the page with no ColdFusion code present and no doctype declaration anywhere.
What do the templates that you used look like? Do you have a preset for this site that you can post along with a copy of the template so that we can look into this some more?
Lee Fuller
This template was created entirely by SAP. I did not create or use any other templates within the site. Further, I have removed all the files from the site - and have re-run SAP to have it rebuild all the files. It did so.. but that did not cure the issue.
I'm not really sure why you are seeing this result, this is why I would like to take a look at the template file that is being used. I understand that it is a SAP template, I would like to see how it is written to your site though to determine why the pages are the way that you see them. If you could also export the SiteAssist Pro site type and layout you are working with I will use these files to investigate the issue further.
Lee Fuller
Actually.. I think I may have found the problem. It appears that the template, itself, had the words at the very top of the source. Also.. the index page has the same two words. I'm surprised that you didn't see it in the code.
I have removed those - republished, and now it is all gone.
I had not opened the template code before - so I did not notice the words at the top of the code source.
That seems to have handled it. Although I still do not know why it happened or why was never corrected by the SAP wizard.
