Control characters appearing in text
Thread begun 7/09/2010 2:17 am by clive.henderson222953 | Last modified 7/19/2010 10:16 am by Jason Byrnes | 1716 views | 3 replies |
Hi
I'm getting control characters (eg <br>) inserted in my text which I don't want.
Not sure what I'm edoing wrong
I've got use <br> for return checked and clean wysiwyg cleaned also checked
The field being updated is defined as longtext
I've got a test page which shows the problem
test.php?id_mnu=1
Any help appreciated
Clive
edit the HTML editor instance. You will need to rebind the Initial value to remove any formatting.
In the Initial value section, click the lightning bolt and select the recordset column that should be used, make sure the formatting is set to none.
Thank You - Resolved
A belated thanks Jason, spot on!
Kind regards
Clive
you're welcome.
