Problem Upload/Resize png files
Thread begun 7/08/2010 12:36 am by paulshoe379536 | Last modified 7/14/2010 2:25 pm by Jimmy Wu | 3424 views | 6 replies |
paulshoe379536
I have a form to upload and resize an image. This appears to be working correctly when I upload a JPG or PNG-8. If I try to upload a PNG-24, it removes the transparency properties of the image and makes the background white. I have ResizeFillColor' => "", but this doesn't help.
What did I miss and what might I be doing wrong?
That section of code below:
// WA_UploadResult1 Params Start
$WA_UploadResult1_Params = array();
// WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => $_SESSION['sponsorImagePath'],
'FileName' => "[FileName]",
'DefaultFileName' => "".((isset($_FILES["sponsorLogo"]))?$_FILES["sponsorLogo"]["name"]:"") ."",
'ResizeType' => "4",
'ResizeWidth' => "175",
'ResizeHeight' => "150",
'ResizeFillColor' => "" );
// WA_UploadResult1_1 End
// WA_UploadResult1 Params End
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1");
if(($_SERVER["REQUEST_METHOD"] == "POST") && (isset($_SERVER["HTTP_REFERER"]) && strpos(urldecode($_SERVER["HTTP_REFERER"]), urldecode($_SERVER["SERVER_NAME"].$_SERVER["PHP_SELF"])) > 0) && isset($_POST)){
WA_DFP_UploadFiles("WA_UploadResult1", "sponsorLogo", "3", "[ExistingFileName]_tmp", "true", $WA_UploadResult1_Params);
Jimmy Wu
This is currently an issue that we are working on. If you aren't resizing the image, you should do a regular file upload instead of a web images only upload.
paulshoe379536
Jimmy,
Unfortunately, PNG files are the primary choice for this use, although they may choose to use JPGs. I believe that I need to make sure that the images are resized during the upload rather than relying on the member to get them right. Also, is there an way to limit the file size that they are attempting to upload?
Do you think the fix for the PNG-24 files will be ready soon? I'll need to come up with some kind of work around if not. Please advise.
Thank you for your help,
Paul
paulshoe379536
If I set the resize option to "None" and the upload still rebuilds my PNG file and jumbles it up.
If I uncheck "Web Images Only", then it will upload the file as is. If I use this as a work-a-round method, how do I insure that the file that is uploaded is a valid image file?
Jimmy Wu
It looks like you have CSS Form Builder, so you can apply some form validation to check if the extension is correct.
To apply this validation, you would want to go to Insert->WebAssist->CSS Form Builder->Client Validation. This should open up an interface to add the validation. You would want to choose the form and the form field and then from the dropdown choose File Extension for the validation type. Then click the plus button and add the validation.
I'm not sure when the fix for the PNG-24 will be ready, so you may want to go with this workaround for now.
paulshoe379536
using the Client Validation has made a good work-a-round for the problem with the PNG files...
Could you please let me know as soon as that is fixed?
Jimmy Wu
If the fix is a simple one, we will post a known issues sticky at the top of the forum.
