Missing Values
Thread began 7/07/2010 4:25 pm by rob294118 | Last modified 8/16/2010 8:23 am by Jason Byrnes | 2908 views | 11 replies |
rob294118
Missing Values
I have a form designed with Form Builder. The list boxes do not send any values. This is what I get:
Contact Info group Confirm by: Array
Project Purpose group Services desired: Array
The form can be viewed here: OnlineDesignQuote.php
when working with multiple select lists, you need to use the PHP implode function to convert the array to a comma separated list:
<?php echo((isset($_POST["Project_Purpose_group_Services_desired"]))?implode)", "$_POST["Project_Purpose_group_Services_desired"]):""?>
rob294118
Code
Where do I put this code?
Shouldn't the Form Builder do this for me? It is a redefined form. I didn't changed anything.
Thanks.
rob294118
It's a "predefined" form.
form builder does not create any code to process the form when it is sent, you need to create the code that processes the form values when it is sent.
this code should be used to output the form values on the page or in an email.
rob294118
Error
The php code gives me a syntax error:
Parse error: syntax error, unexpected ')' in /homepages/20/d184490718/htdocs/PyxelsDesignStudio/WA_Universal_Email/Email_Templates/design_quote.php on line 11
rob294118
Error in Code
What should the code be? This gives me an error. Thanks.
<?php echo((isset($_POST["Project_Purpose_group_Services_desired"]))?implode)", ", $_POST["Project_Purpose_group_Services_desired"]):"") ?>
sorry, slight syntax error. it should be:
<?php echo((isset($_POST["Project_Purpose_group_Services_desired"]))?implode(", "$_POST["Project_Purpose_group_Services_desired"]):""?>
rob294118
Thanks Jason.
you're welcome.
