Changing log in password has caused problems
Thread begun 7/07/2010 7:11 am by nick354316 | Last modified 7/07/2010 12:12 pm by Jason Byrnes | 2888 views | 3 replies |
nick354316
Having finished the installation of PowerCMS2, I added the needed content, and all was good. I was finally ready to turn the site over to my client.
I decided to change the log in password to a simpler one as I was certain that my client would change the one that I had set up.
So I changed the password, confirmed it by entering it again, and hit 'save.'
When I navigated to the page with the CMS content, I got the following error message just above the content edit symbol:
Parse error: syntax error, unexpected T_STRING in /home3/argoctsc/public_html/franksproduce/powercms/WA_Globals/WA_Globals.php(58) : eval()'d code on line 1
When, in order to navigate to the login for PowerCMS, I click on an editable region, I get the following error on a blank page:
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home3/argoctsc/public_html/franksproduce/powercms/WA_Globals/WA_Globals.php(58) : eval()'d code:1) in /home3/argoctsc/public_html/franksproduce/powercms/WA_SecurityAssist/Helper_PHP.php on line 5
Warning: Cannot modify header information - headers already sent by (output started at /home3/argoctsc/public_html/franksproduce/powercms/WA_Globals/WA_Globals.php(58) : eval()'d code:1) in /home3/argoctsc/public_html/franksproduce/powercms/WA_SecurityAssist/Helper_PHP.php on line 67
When I navigate via the address bar of the browser to the PowerCMS log in page, I get the log in page, but the following errors are found at the top of the page:
When I then try to log in (blindly hoping that I would be able to get in), I get the following error messages:
Warning: Cannot modify header information - headers already sent by (output started at /home3/argoctsc/public_html/franksproduce/powercms/WA_Globals/WA_Globals.php(58) : eval()'d code:1) in /home3/argoctsc/public_html/franksproduce/powercms/admin/users_login.php on line 45
Warning: Cannot modify header information - headers already sent by (output started at /home3/argoctsc/public_html/franksproduce/powercms/WA_Globals/WA_Globals.php(58) : eval()'d code:1) in /home3/argoctsc/public_html/franksproduce/powercms/admin/users_login.php on line 48
The page with the editable content is a page that you need to be able to log in in order to view it. I used Security Assist to create the page(s). I intitally got error messages after the initial install. I then checked the forums, and saw the entry that indicated that line 5 of the WA_CMS.php page should be commented out. I did that (just the commented out part), and everything worked.
The problem came when I changed the password. In the interest of expediting this, I am including a zip with the files listed in the error messages, and the page that contains the editable content.
Thank you for your prompt attention to this. I desperately need to get this turned over to my very, very anxious client.
change line 58 of the WA_Globals/WA_Globals.php file:
eval("\$WAGLOBAL_".$value[$x][4]."='".replaceTokens($value[$x][1],$tabs)."';");
eval("\$WAGLOBAL_".$value[$x][4]."='".addslashes(replaceTokens($value[$x][1],$tabs))."';");
nick354316
Hi Jason - Thanks for getting back to me so quickly on this. I changed the line of code, and the error messages have disappeared and I am able to log in.
Unfortunately, I am no longer able to edit the content. When I clicked 'edit,' I am taken to the Content Editing page, and a dialog box immediately pops up with the heading of "Message from webpage," and the message "Toolbar set "Custom" doesn't exist." And the only option is to click OK, and close the window.
I have attached a png of the dialog box.
Thanks again.
login.php
