iRite looking for php connector, but I'm using ASP!
Thread begun 6/03/2009 3:16 am by YellowCircleWeb | Last modified 6/03/2009 4:05 pm by YellowCircleWeb | 4506 views | 3 replies |
YellowCircleWeb
I'm trying to build a page that allows me to upload an image file to the server using iRite. I'm using ASP code to do this and an Access database.
When I attempt to browse the server using the iRite image upload app I get the following error message:
"The server didn't send back a proper XML response. Please contact your system administrator."
The image browser is looking for a PHP connector and not finding one so I'm getting the error.
The end of the URL the iRite dialog is looking for is:
'WA_iRite/editor/filemanager/browser/default/browser.html?Type=Image&Connector=../../connectors/php/connector.php'
How do I change this so it look for the ASP Connector? Everything is set up for ASP and the image browser is the only thing not working correctly in my iRite pages.
Any help is appreciated.
There is a line you need to update in the configuration.
It should be documented in the help or in a tutorial associated with iRite since it is obviosly a common update, or you can just look through your configuration js file for ".php" to see where it is specified and make the necessary adjustments.
Neil Beadle
Adding Insert Image Feature to your iRite Image toolbar
Have you taken a look at the Solution Recipe for Adding the Insert Image Feature to iRite?
By default, iRite references PHP and ASP or ColdFusion users will need to change this.
Follow the Solution Recipe for Adding an Insert Image Feature here irite_images/
YellowCircleWeb
Thank you very much for your help on this. I think that should solve my problem.
