Menu not appear properly in IE7
Thread begun 7/06/2010 4:33 am by jack343289 | Last modified 9/07/2010 12:52 pm by Jason Byrnes | 3144 views | 6 replies |
jack343289
When Siteassist Professional builds the pages - the menu appears as a line of text, strung together in IE7 (which is clickable), but with none of the styling.
I did notice the comment about IE6 and the changed code in the head, but it does not work for IE7
Ca you help?
Regards
Jack
please post a link where O could see the problem to investigate the cause of the issue.
jack343289
I have done no work to the initial pages generated, the link is www.designerinks.com
Thank you
Jack
when i view source of the page, there is no doctype tag.
change:
undefined
undefined
<head>
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
<html>
<head>
jack343289
Thank you for bringing that to my attention - it works ok now.
I didn't realise that Siteassist Professional did not put them in automatically - Am I missing something here? - Is there a setting that I must choose to have this inserted when the pages are built?
Thank you
Jack
nigel258085
Menu styles wrong
Jason - do you know why the DOCTYPE isn't inserted? I have had this problem after installing 'new' upgrades to DW extensions. I think this may be incorrect versions of various files when installing upgrades - in Adobe Extension Manager I have had to click on 'no, don't replace this file' hundreds of times (the Manager reports the version being installed is older than existing). As a result I am now forced to click on 'Yes to all' which means I end up with 'older' versions of the various component files - there is no alternative 'No to all' button! I may raise this as a separate thread by the way which I hope you won't mind.
you also asked this in a nother thread:
showthread.php?t=13758
I opened a ticket for you there to look into the problem.
