UE
Thread begun 7/06/2010 12:42 am by david331670 | Last modified 7/13/2010 1:42 pm by Eric Mittman | 2999 views | 4 replies |
david331670
UE
Stuck again, Can you please help.
I have created a form with name address, email, comments area etc.
I have a recordset for the required details, This recordset includes Thumbnail details.
I have also created a dynamic list that displays a series of items for the user to select from.
(series of Photos). I have given each photo a item code, this code(number) is displayed in the drop down list. I have created a UEmail html message where I can send all the data to myself, no problem. However I would like to display the image I selected from the drop down list in the email ( I have done this before from a cart page). How can I get the thumbnail ID from the form data to display an image in the email sent to me?
I would appreciate any help.
Thank you
David
ps
I hope you had an enjoyable 4th of July Holiday
Are you passing the information from the select list to your page with the UE server behavior on it? If so you can add in a recordset to this page and filter it on the posted id for the image. Then you can reference the image from the recordset in the email message using the bindings.
If you need any more help with this please post back and include any further details about your setup and the message body, what you have tried, and what the current result is.
david331670
UE
This post has been deleted.
If you are able to get one showing with a particular recordset but it is showing for the first record only then it would seem that the recordset is not being properly filtered on the form value.
If you can post back with a copy of a page that has this working but not filtered properly as well as the page that does the posting so that I can compare what you have here with the current result you are getting.
david331670
UE
Thank you for your help.
Penny dropped
David
Glad to hear that, let us know if you have any other questions or run into any other problems.
