Linking a target ifram
Thread begun 7/05/2010 6:22 pm by rkteach | Last modified 7/09/2010 11:57 am by dave260615 | 1394 views | 2 replies |
rkteach
Hi need to know how to link to an iframe, i don't see target input anywhere.
menu writer does not support the target attribute in the wizard, you would need to add the target attribute to the link manually after the menu is created.
dave260615
Be warned
What Jason fails to mention is the fact that once you add the target manually, you essentially can no longer use CSS Menu writer. Because if you do, it overwrites all your menu data, including all the custom targets you've added.
Just stating the sad facts.
PS - Adding the target manually is a bit crazy, since people buy this product to automate their code, and specifically NOT have to manually write code....
