problem installing security assist 119
when i try to install security assist 119 I get a message saying "can not update menus security assist extension will not be installed"
I have tried deletting the config file to no avail
Keith
Keith
follow step 2 on the following page:
146/
I am trying to install Security Assist 1.1.9, but can't I get this error: "Can't update menus. The extension will not be installed."
Thanks.
This error message means that the configuration folder has become corrupted. You will need to rename the users configuration folder. To locate the users configuration folder, see the Common installation issues PDF:
once you locate the users configuration folder, rename it to configuration_bak, then open the extension manage. You should select each extension, and uninstall it, then reinstall them.
