Multiple Domains - No solutions work
Thread begun 7/05/2010 3:37 pm by phoyer313083 | Last modified 7/09/2010 7:10 am by Jason Byrnes | 3478 views | 5 replies |
phoyer313083
I am trying to get two different domains with two different Google API keys to work. I have tried the two PHP solutions in other threads in this form, the Google javascript solution, and other javascript solutions found through a Google search. None work. When I display the page, all I get is the error message saying the saying the domain needs an API key. The web hosting is 1 & 1 using a Linux server. Any help coming up with a solution would be appreciated.
please post a link to each of the two pages and the code you are using so I can examine what is wrong.
phoyer313083
Sorry for not getting back with you yesterday. I had a meeting after work. The first thing I tried was:
<script type="text/javascript" src="google_javascript/wagmp_map_14.js">/*wagmp*/</script>
switch ((isset($_SERVER["SERVER_NAME"]))?$_SERVER["SERVER_NAME"]:"") {
case "www.atlantasinglesgolf.com":
$key = "ABQIAAAA_hh3SY5PFw7FaZnZc_GE8BTU7MCzZCeLoxH0VKX7ffetWjYcUhQ06yq2HnOxNdpxS65um3bz63yxtg";
break;
case "www.asgaatlanta.com":
$key = "BQIAAAA_hh3SY5PFw7FaZnZc_GE8BT-0cRtB7JP2p2BDDXM_yBQn3Gx2BRjSQGnx5e2yh-WKG8dTy0S9yZRBw";
break;
default:
break;
<script type="text/javascript" src="http://maps.google.com/maps?file=api&v=2&key=<?php echo $key; ?>">/*wagmp*/</script>
This was tried with and without the www.
Then I tried (with and without www.):
<?php echo((isset($_SERVER["HTTP_HOST"]))?$_SERVER["HTTP_HOST"]:"") ?>
switch ($_SERVER["HTTP_HOST"]) {
case "atlantasinglesgolf.com":
break;
case "asgaatlanta.com":
break;
default:
break;
This works with atlantasinglesgolf.com but not asgaatlanta.com:
<script type="text/javascript" src="http://maps.google.com/maps?file=api&v=2&key=ABQIAAAA_hh3SY5PFw7FaZnZc_GE8BTU7MCzZCeLoxH0VKX7ffetWjYcUhQ06yq2HnOxNdpxS65um3bz63yxtg">/*wagmp*/</script>
Any help would be appreciated.
Thanks...Pat
please post a link to the map page for both domains.
phoyer313083
A link that the map display's is:
Bentwater.html
A link that the map does not display is:
Bentwater.html
The page is the same as both domains use the same web hosting site and the html in the page is using the html built by Pro Maps for Google.
looks like the host does not define the HTTP_HOST variable.
add the following to the page just after the <body> tag to see which server variables are getting set:
<pre><?php var_dump($_SERVER); ?></pre>
use that to find a server variable that is being set by the host that can be used in the if statement.
