Double input in web url
Thread begun 7/05/2010 1:55 pm by warrenphillips25336771 | Last modified 7/05/2010 4:24 pm by neilo | 2013 views | 3 replies |
warrenphillips25336771Beta Tester
Hi
got a site I am working on at (www).gmbcringlewoodclub.co.uk and when I click a link it fails as the url is entering double, can someone please tell me where I can change this!
thanks
tom250037Beta Tester
The links your links in your menu are set to /gmbcringlewoodclub.co.uk/pagename.php
Just remove the /gmbcringlewoodclub.co.uk and enter just the page name like /aboutus.php
That should take care of it.
Tom
Hi tom
they are dynamic from sitescribe using the built in cms, it worked ok the other day
neilo
Are the menus unchanged from when you uploaded them (with the other Site Sculptor files and folders), or have you added the menus as editable regions in the CMS and added or altered the links from there?
If the latter, you could check that the correct path for remote root has been entered in to the CMS database.
If the former, you could try the following:
Check these files on your remote server:
CSSMenuWriter/cssmw/menu.php
CSSMenuWriter/cssmw_content/menu.php
CSSMenuWriter/cssmw_home/menu.php
Try altering the second line of each (after backing up the files) from:
$WA_remoteRoot = "" . $WAGLOBAL_pcms_remote_root . "";
$WA_remoteRoot = "/";
Don't forget to back up the three files first.
