2nd gallery does not show any pictures
Thread begun 7/05/2010 2:11 am by this_is_me | Last modified 8/11/2010 6:40 am by Jason Byrnes | 4318 views | 8 replies |
this_is_me
I have another gallery running and it works as expected but I cannot find any pictures in the new gallery.
All pictures are correctly stored in the database. I can add pictures and they are shown in the administration area. But no pix are shown in the public area ...
please post a link where I can see the problem to investigate the cause.
this_is_me
here it is
index.php?gallery=4&theme=dark
If you change the number from 4 to 3 you'll see the other gallery which is working.
thank you
if I refresh the page a few times, it will start to try and load the images.
Seams like a database connection issue. on the index.php page, add the following at line 1:
error_reporting
(E_ALL);
I'm wondering if there are any PHP errors being reported that may help determine the cause.
this_is_me
error_reporting
(E_ALL);
Hmm,
can't see any ...
page code starts with:
error_reporting(E_ALL);
//gallery id, theme
if(empty($pg_id)) $pg_id = $_GET['gallery'];
if(empty($pg_theme)) $pg_theme = 'dark';
if(isset($_GET['theme'])) $pg_theme = strtolower($_GET['theme']);
//set config
$abs_file = str_replace('\\', '/', dirname(realpath(__FILE__)));
$abs_prefix = substr($abs_file, 0, strrpos($abs_file, '/') + 1);
$included = strtolower(realpath(__FILE__)) != strtolower(realpath($_SERVER['SCRIPT_FILENAME']));
include($abs_prefix . 'global.php');
this_is_me
any more code you need?
<ping> <ping> <ping>
login.php
this_is_me
Again, its a UTF-8 / character problem
Thanks to the excellent phone support we could figure out the problem. The second gallery used titles with French letters, like Ardèche or Chârtreuse. The use of one single letter like this caused the whole gallery to disappear! As a quick-and-dirty workaround, one could encode some letters, like the old fashioned &szlig; for ß or &auml; for ä. It then displays wrong in the admin area, i.e. "Stra&szlig;e" instead of Straße. But on the public gallery page it will display correctly.
This is rather unsatisfactory. It excludes non-encodable characters completely. Please fix this asap!
we are currently investigating the cause of this problem and will release a fix when it is available.
