Problem with Cart
Thread begun 7/02/2010 12:43 pm by J7HNW | Last modified 7/07/2010 12:02 pm by Eric Mittman | 7938 views | 21 replies |
J7HNW
Problem with Cart
I have just run through the checkout Wizard and completed all forms. I set it to use Sagepay Server
All appears to have worked until you enter address etc and press the button. The confirmation page comes up and then you press another button.
I am then getting this error
Warning: Missing argument 6 for waue_definition() in C:\inetpub\vhosts\hair-for-men.com\httpdocs\WA_Universal_Email\mail_PHP.php on line 69
Fatal error: Call to undefined function: microtime_float() in C:\inetpub\vhosts\hair-for-men.com\httpdocs\confirm.php on line 176
I do not understand this as the site is in c:\xampp \htdocs\hairformen and not in inetpub.
Is this the problem ? The WIzard showed the path to Xampp !!!! Very confused - my first e cart 5 project !
Please advise. I attach both files Zipped files - copied from the XAmpp\htdocs\hairformen folder. Very urgent please - must have running by Sunday.
How have you setup your local site and testing server setting in DW? Unless you have this same location mapped to a virtual directory in your IIS I'm not sure why you would get this error. It looks like a server configuration issue.
J7HNW
Server
My Testing Server is set up as :
c:\xampp\htdocs\hairformen\httpdocs\
URL Prefix: httpdocs
My Local server is set up as:
Local root folder: C:\xampp\htdocs\hairformen\httpdocs\
Default images folder: C:\xampp\htdocs\hairformen\httpdocs\graphics\
Links relative to document - ticked
HTTP address: 188.65.32.201/httpdocs/
I am running this live now anyway - so it is not the testing server but the real site which is throwing up this error. The Site is fine - all dynamic pages and cart are working fine. I have just simply gone through the checkout wizard - which again showed the paths correctly and this is what I get.
URGENT ADVICE required please from anybody
tom250037Beta Tester
It looks like you have code in here for universal email version 3, and version 4 in the same page. I dont know if that can cause an issue.
on confirm.php lines 127 through 140 send out an email whose content is in WA_Universal_Email/WAUE_confirm_1.php using Universal email 3.0
on confirm.php lines 141 through 228 it sends out another email whose content is in webassist/email/waue_confirm_1.php using Universal email 4.0
Its in this block that the fatal error microtime_float() is occurring. microtime_float() is a function defined in webassist/email/mailformatting_php.php.
Are you sure you uploaded all your include files, especially the /webassist/ folder?
Tom
J7HNW
Still a problem
Hi Tom and thank you so much for your help
I have removed the older UEM3 code and the microtime_float has disappeared - well done .
However i am now getting the following code all of which still refers to inetpub\vhosts despite the fact that the site is all set up in Xampp ( See attached screenshot directly from the Server admin panel )
Any ideas please ?
Thank you
John
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at C:\inetpub\vhosts\hair-for-men.com\httpdocs\confirm.php:130) in C:\inetpub\vhosts\hair-for-men.com\httpdocs\confirm.php on line 182
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at C:\inetpub\vhosts\hair-for-men.com\httpdocs\confirm.php:130) in C:\inetpub\vhosts\hair-for-men.com\httpdocs\confirm.php on line 182
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at C:\inetpub\vhosts\hair-for-men.com\httpdocs\confirm.php:130) in C:\inetpub\vhosts\hair-for-men.com\httpdocs\webassist\email\mail_php.php on line 285
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at C:\inetpub\vhosts\hair-for-men.com\httpdocs\confirm.php:130) in C:\inetpub\vhosts\hair-for-men.com\httpdocs\webassist\email\mail_php.php on line 285
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at C:\inetpub\vhosts\hair-for-men.com\httpdocs\confirm.php:130) in C:\inetpub\vhosts\hair-for-men.com\httpdocs\confirm.php on line 212
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at C:\inetpub\vhosts\hair-for-men.com\httpdocs\confirm.php:130) in C:\inetpub\vhosts\hair-for-men.com\httpdocs\confirm.php on line 212
Warning: Cannot modify header information - headers already sent by (output started at C:\inetpub\vhosts\hair-for-men.com\httpdocs\confirm.php:130) in C:\inetpub\vhosts\hair-for-men.com\httpdocs\confirm.php on line 259
that path C:\inetpub\vhosts\hair-for-men.com\httpdocs\ is the full path on your remote server (must be a windows server).
I would look near line 130 on confirm.php. I would guess that you left a blank line between a closing php tag and the next opening php tag like this
remove any blank lines this that are outside of the php tags. That is what is triggering your error.
Tom
J7HNW
Thank you Tom - you are a atar !
This post has been deleted.
J7HNW
Thank you Tom - you did it again !!
Tom
Thank you so much - you pinpointed the 2nd problem - which was a blank space on line 129.
All now working
I cannot thank you enough for your expertise.
Best regards
John
J7HNW
Is this correct
Sorry - Tom has kindly helped me out and no I am showing no errors on the confirm.php page. However when I press after adding my Shipping info and then press the SUBMIT ORDER button on the "confirm.php" page - I am getting this error instead of being sent to Sagepay
Transaction Not Completed
We're sorry
Your transaction could not be completed.
Please can you help. I am really sorry to have to keep asking questions - but this is my first ever PHP MySQL site. I have no idea what is wrong or where to start looking.
Interestingly though I have received the E Mail receipt for the test order. WHy is it not sending the customer toSagepay please ?
Thank you
John
You are very welcome. Glad I could be of assistance.
Tom
