Checkbox Group vs Checkbox and DataAssist
Thread begun 7/01/2010 5:11 pm by andy.schofield283961 | Last modified 7/07/2010 6:57 am by Jason Byrnes | 2813 views | 6 replies |
I have a result page on my site which lists records found and I want to place a checkbox by the side of each with contains the record ID. I then want to submit this page to an update page which takes these ID's as a parameter and updates the database.
The problem is if I use checkboxes using dataassist search it appears to only select the the last one clicked. At first I thought it was because I was using checkboxes so i made a checkbox group thinking that would help, but no difference.
Am I missing something really obvious.
to pass multiple values using a checkbox, the name must end in '[]' to create an array, for example:
<input type="checkbox" value="1" name="checkbox[]" />
Thanks Jason,
Managed to get it working, although it took a little editing after applying dataassist search wizard.
I created the results page manually where the recordset selects everything and then applied the search wizard. This works now but if I select nothing in my checkboxes then I get all results applied to the recordset.
I tried changing the default where clause but still no joy. Can you help?
Any ideas on how I can solve this, i keep trying but had no joy. Any help very much welcomed.
set the trigger for the search to use the checkboxes and set the default where clause to 0 != 0.
click the lightning bolt next to trigger and select the checkbox form the form collection.
In the Default Where section, type:
0 != 0
Jason,
I have tried to follow as you directed. I assumed you meant checkbox from the form collection. I had to remove the [] from the checkbox name pulled in by the form collection for it to work. But then all was good.
And i added the default where clause...code looks like this
$WADbSearch1_DefaultWhere = "0 != 0 ";
if ((((isset($_POST["chkBoxCherryID"]))?$_POST["chkBoxCherryID"]:"") != "")) {
$WADbSearch1 = new FilterDef;
$WADbSearch1->initializeQueryBuilder("MYSQL","1");
But it still shows all, i know this is because I dont understand the code, but if you can help me it would be appreciated.
Andy
please send a copy of your page.
