URGENT!!! Files not uploading on insert
Thread begun 6/30/2010 11:12 am by zuffster370186 | Last modified 6/30/2010 3:12 pm by Jason Byrnes | 1904 views | 3 replies |
zuffster370186
I have an Insert Page where one could upload up to 5 files/images. When Insert is clicked, all the other information on the form is submitted to the DB but not the files.
In the database, I have five columns for img1, 2, 3, 4.... The images are not uploading to the file folder specified
HOWEVER
when I go to update that record and select the files/images I want to upload, it works.
Why is this not working on the insert page. I have been working with Digital File Pro 2 since it came out and have not had this problem before.
See my attached php insert page!
for image upload thio function, the forms encoding type must be set to multipart/form-data.
edit the form tag:
<form action="homestay_Insert.php" method="post" name="WADAInsertForm" id="WADAInsertForm">
<form action="homestay_Insert.php" method="post" enctype="multipart/form-data" name="WADAInsertForm" id="WADAInsertForm">
zuffster370186
Thanks Jason! That worked. If I have more than one file upload in a form, do I have to change the Form Encryt manually everytime?
If you use Dreamweaver to insert the file fields, it will change the enctype automatically.
If you manually add the files fields, you will need to manually change the enctype.
