DA Sort
Thread began 6/02/2009 11:42 am by xag | Last modified 6/05/2009 6:18 am by xag | 10879 views | 21 replies |
xag
DA Sort
Hello
I'm stuck making the column headers as links to pass the parameter to sort. In the DA Sort function I have the trigger being cStr(Request.QueryString("SortColumn")). I created SortColumn in the Binding panel. Next I have in the Sorting Area as my column with cStr(Request.QueryString("SortColumn")) and Sort order as Ascending.
Now here is where I get stuck. The table is currently only showing the first 15 records. When I go to make the table header a link i first put the filename i am working on then click in Parameters and click the dynamic pan in name... what should be the name and what should be the value? and how can I still make it work with the filtered querystring.
Thanks for yo help
I think the name should be: SortColumn and the value should be the column name.
xag
This is the SQL error I get
--[Microsoft][SQL Server Native Client 10.0][SQL Server]A column has been specified more than once in the order by list. Columns in the order by list must be unique.
Do you already have an Order By you have added to the recordset? Remove that one and just use the server behavior.
xag
No I don't I tried to follow the soulution receipe but he never said anything if you have a recordset paging. I keep getting an error. I have my trigger as SortColumn is it suppose to be my Binding Sort or the filtered QueryString? Then in my sorting area is it suppose to be my Sort Binding ? Or am I suppose to be putting the column name?
xag
This is what the link I have in the header
<th class="WADAResultsTableHeader"><a href="/ControlPanel2s.asp?<%=cStr(Request.QueryString("Sort"))%>=USER_ID">USER_ID:</a></th>
Then my trigger is cStr(Request.QueryString("Sort")) and in my sorting area I have cStr(Request.QueryString("Sort")) as the column and Ascending as the order. When I save and test the page the sort link is not going anything and only returning this .asp?=USER_ID
It should probably be:
<th class="WADAResultsTableHeader"><a href="/ControlPanel2s.asp?Sort=USER_ID">USER_ID:</a></th>
xag
Yup thats what I thought so I manually changed it with no avail. Also the default query is with no sort. and no sever behavior on the whole page. Also the sort is not respecting the page offset when recordset navigation button is pressed.
Have you read the help documentation on the feature? There is another part you need to add to your <a> tag to maintain the other url parameters.
Maybe ignore the fact that navigation doesn't work so you can concentrate on one thing at a time. There is functionality included to solve that problem, but concentrate on one thing at a time.
Once it is sorting we should be able to get it maintaining the url parameters so that navigation will work.
xag
Hi Ray,
I've been taking my time with this and have a very simple page that just dumbs all of 5 records on a page. i've been trying to do this URL paramater with the header and it's not passing a value in the URL
Here is my header
<a href="/SortTest.asp?LOG_KEY=<%=cStr(Request.QueryString("ColumnSort"))%>">
LOG_KEY</a>
LOG_KEY is the header to my first column that is unsorted.
Attach is a screen shot of the Sort feature from DA.
thanks
