PS3 and Ecart Shipping
Thread begun 6/30/2010 2:50 am by MikeH | Last modified 6/30/2010 10:53 am by MikeH | 3089 views | 6 replies |
MikeH
Hi
I am trying to change the shipping rates using ecart all is going welland working for shipping rates based on price.
Question: Is there a way to give a choice of shipping in PS using ecart for example.
All orders under £100 attract a £3.50 shiping cost ( no problem and working)
How would I give the customer an option to choose a premium delivery service if they want for ie £6.50?
So they would have a choice:
Standard - £3.50
Next Day - £6.50
Is this possible?
Thanks in advance
Mike
On the checkout page, add a select list to choose the shipping type:
<select name="shippingType" id="shippingType">
    <option value="Standard">Standard</option>
    <option value="Next Day">Next Day</option>
</select>
On the confirm page, there is a collection of hidden form elements, add a new hidden form element to the collection using the same name as the oner from the checkout page, and set it to capture the value posted from the checkout page:
<input name="shippingType" type="hidden" id="shippingType" value="<?php echo((isset($_POST["shippingType"]))?$_POST["shippingType"]:""?>" />
Near the top of the confirm page, there is code to set session values from the form elements posted from the checkout page, add the following code to set a new session value for the shipping type:
if (!session_id()) session_start();
if(
$_SERVER["REQUEST_METHOD"] == "POST")     {
$_SESSION["shippingType"] = "".((isset($_POST["shippingType"]))?$_POST["shippingType"]:"")  ."";
Now add a new trigger to the standard shipping rule:
Based On Session Variable Value
If the session Variable 'shippingType' has a value of 'Standard'
When creating the Next day shipping rule, add the trigger:
If the session Variable 'shippingType' has a value of 'Next Day'
MikeH
Thanks Jason
Had a feeling it was on those lines but thats perfect thank you.
Once again your support is exceptional.
Mike
you're welcome.
MikeH
Jason
Im using PayPal express only so it misses out the checkout page and goes direct to PayPal.
Where would you put the code in that situation?
Mike
with payapl express, this cannot be accomplished.
MikeH
Not to worry Jason that code will come in useful another time. I did think that PP Exp may have had a limitation.
Mike
