Broken PHP in WA_CalculatedHash
Thread begun 6/02/2009 10:32 am by mike264653 | Last modified 8/25/2009 5:46 pm by tom92909 | 10800 views | 8 replies |
mike264653
I used the eCart 4.5 wizard to create a cart connecting to Authorize.net. When I went to view my pages to see the info pass my confirm.php displayed up until the hidden fields and then nothing. After commenting out different codes I found this line generated by the wizard that was breaking the page. I don't know what needs to be edited to make it work.
<?php $WACalculatedHash = WA_CalculateHash("MYIDNUMBER", "MYKEYNUMBER", "".$Frubob_eCart->GrandTotal() ."", "".AuthNet_RandomID() ."", "USD")?>
I am running this on a MAMP apache server with PHP 5.2.6 with HASH enabled and the MB5 engine.
Maybe the include file is missing so that function isn't properly defined? Do you get a specific error? When you view the source can you maybe see an error in one of the last lines of the html before it stops displaying?
mike264653
Error from source
<b>Fatal error</b>: Call to undefined function mhash() in <b>/Users/HD_Purple/Sites/frubob/WA_eCart/checkoutScripts/WA_simlib.php</b> on line <b>30</b><br />
Line 30 from WA_simlib.php
return (bin2hex (mhash(MHASH_MD5, $data, $key)));
Sounds like your version of php doesn't have mhash installed:
mhash
mike264653
MHASH vs HASH
php.net says that the mhash extension is obsolete and replaced by hash. Is there a way to run the eCart to Authorize.net using hash, which is enabled on my server?
Authorize.net suggests using hmac for php versions later than 5.1.2. How can I get the eCart you use this?
You can update that one line of code. Currently it uses mhash, but it is only used in that one place, so you can try updating it to hash or hmac.
tom92909Beta Tester
I'm getting a similar error message...
I'm using PHP & MySQL. eCart v4.5 with Authorize.net and my confirm.php to my checkout_success.php page transition is giving me the following...
Warning: require_once(WA_eCart/checkoutScripts/WA_simlib.php) [function.require-once]: failed to open stream: No such file or directory in /public_html/checkout_success.php on line 10
Fatal error: require_once() [function.require]: Failed opening required 'WA_eCart/checkoutScripts/WA_simlib.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /public_html/checkout_success.php on line 10
I have no /checkoutScripts/WA_simlib.php directory below WA_eCart.
Standard installation of the extension and a clean new cart creation from scratch...?
Search your user configuration for that file "WA_simlib.php" and move it to the appropriate location. It should be created automatically, but something must have prevented that.
tom92909Beta Tester
Thanks. That was a little strange, but I was able to manually create the directory and add the required file.
lilryansd360589
same problem
This post has been deleted.
