image size
Thread begun 6/29/2010 12:16 pm by i.edwards384429 | Last modified 6/29/2010 5:15 pm by i.edwards384429 | 1592 views | 2 replies |
i.edwards384429
image size
Hi
seem to have an issue with file uploading (attached code)
I set the upload to web images and to resize to 450 px width.
Upload works files are uploaded and my database record written problem is the images are not resized to 405 width they are:
514 * 768
512 * 768
1024 * 682
1024 * 682
504 * 768
clearly I've done something wrong
can you take a look please
thanks
Ian
the code looks correct, How are you verifying that the width is not changing?
Are you examining the files directly on the server? or are you looking at the image in a web page? If you are looking at the image in a web page, it could be that the image tag has a height or width attribute set that is overriding the actual file width.
i.edwards384429
update
Hi Jason
if I look at the model_images directory on the web server thats the size of the images.
The size is being reduced but not to the 450 I want, which is weird.
I suspect it's to do with the images I'm using so I'll try some different ones and get back to you tomorrow if I still have a problem. At least I know the code is correct
thanks
Ian
