State and zip code
Thread begun 6/29/2010 11:39 am by lih400228 | Last modified 6/29/2010 5:08 pm by Jimmy Wu | 2722 views | 3 replies |
lih400228
State and zip code
User Registration Solution Pack
How can I fix the zip code and states in my form when I am not living in the US?
In Norway we have only four characters in our zip code.
The states option can be deleted.
Jimmy Wu
Find line 878, which should look like this:
var sprytextfield8 = new Spry.Widget.ValidationTextField("sprytextfield8", "none", {validateOn:["blur"], minChars:5, maxChars:10});
on the users_Registration.php page. Change the minChars and maxChars to match with how it should be for your country's zip.
Deleting the zip from the form is a little more complicated. The easiest way to get this to work is to just have the state field have a default value and insert that default value into the database. You can delete all the options except for the first two. Then you would want to move the selected="selected" to the second option. then you would want to set the span tag to have a style setting the visibility to hidden. Next you would want to remove the </tr>, <tr> and <th>State:</th> tags above the span tag. The end result should look like this (I've included the city table row as well):
<tr>
<th>City:</th>
<td><span id="sprytextfield7">
<input name="UserCity" type="text" class="WAATKTextField" id="UserCity" onBlur="if (document.getElementById('cityServerValidation')) document.getElementById('cityServerValidation').style.display='none'" value="<?php echo(ValidatedField("usersRegistration","UserCity")) ?>" size="32" />
<span class="textfieldRequiredMsg">A value is required.</span></span>
if (ValidatedField("usersRegistration","usersRegistration")) {
if ((strpos((",".ValidatedField("usersRegistration","usersRegistration").","), "," . "16" . ",") !== false || "16" == "")) {
if (!(false)) {
<span class="textfieldServerError" id="cityServerValidation">
Please enter your city. </span>
<?php //WAFV_Conditional users_Registration.php usersRegistration(16:)
}?></td>
<td><span id="spryselect1" style="visibility:hidden">
<select name="UserState" id="UserState" onBlur="if (document.getElementById('stateServerValidation')) document.getElementById('stateServerValidation').style.display='none'" onChange="if (document.getElementById('stateServerValidation')) document.getElementById('stateServerValidation').style.display='none'" >
<option value="" <?php if (!(strcmp("", (ValidatedField("usersRegistration","UserState"))))) {echo "selected=\"selected\"";} ?>>Choose a state</option>
<option value=" " selected="selected" <?php if (!(strcmp(" ", (ValidatedField("usersRegistration","UserState"))))) {echo "selected=\"selected\"";} ?>>N/A</option>
</select>
<span class="selectRequiredMsg">Please select an item.</span> </span>
if ((strpos((",".ValidatedField("usersRegistration","usersRegistration").","), "," . "17" . ",") !== false || "17" == "")) {
if (!(false)) {
<span class="textfieldServerError" id="stateServerValidation">
Please choose your state. </span>
<?php //WAFV_Conditional users_Registration.php usersRegistration(17:)
}?></td>
</tr>
lih400228
Jimmy
Thank you :-)
Have a nice day
LIH
Jimmy Wu
You're welcome. If you run into any additional issues, feel free to open a new thread.
