UK Phone formating and validiation
Thread begun 6/29/2010 8:13 am by aladdin229745 | Last modified 7/07/2010 12:29 pm by aladdin229745 | 12647 views | 11 replies |
aladdin229745
Does anyone use form builder in the UK.
When I enter a UK number it is formatted like this 0 (139) 234-1888
It should be 01392 431 888. Obviously it is not passing validiation either.
I had a look at the SpryValidationTextField.js
'phone_number': {
formats: {
//US phone number; 10 digits
'phone_us': {
pattern:'(000) 000-0000'
'phone_custom': {}
I have changed to
'phone_number': {
formats: {
'phone_us': {
'phone_custom': {
pattern:'00000 000000'
But no luck, also in the UK some numbers are 10 and some 11.
Please can someone tell me how to set this up.
Many thanks
find the line that initializes the phone spry validation.
It will look likle:
var Registration_group_Phone_Spry = new Spry.Widget.ValidationTextField("Registration_group_Phone_Spry", "phone_number", { format:'phone_us' , validateOn:["blur"]});
and change it to use your custom pattern:
var Registration_group_Phone_Spry = new Spry.Widget.ValidationTextField("Registration_group_Phone_Spry", "phone_number", { format:'phone_custom' ,pattern:"00000 000 000", validateOn:["blur"]});
In the patern, you can change the last character to a '?' to allow any character, the will need to enter a space for at the end of the 10 digit phone number. for example:
pattern:"00000 000 00?"
would allow the phone number to be enter as "12345 123 12 " or "12345 123 123"
aladdin229745
Hi Jason
Thanks for your reply.
Am I to look in SpryValidationTextField.js for these lines. Because I cannot find them in there.
no, near the bottom of the form page, there will be a script block that contains a line to initialize each spry form element.
The name of the spry variable will be different on your page, if you need help finding it, post a copy of your page.
aladdin229745
Hi Jason,
Thanks, I have found the code and changed it as you have recommended. However, I am still having the same problem. You can check it out from this link and also see the source code.
form.html
I appriciate your help.
Aladdin
client validation is also applied to the fild causingthe issue..
change:
<input id="Appointment_request_group_Phone" name="Appointment_request_group_Phone" type="text" value="" class="formTextfield_Large" tabindex="5"  onblur="WAValidatePN(document.getElementById('AppointmentRequest_Brassy_Default').Appointment_request_group_Phone,'',false,true,'x (xxx) xxx-xxxx',document.getElementById('AppointmentRequest_Brassy_Default').Appointment_request_group_Phone,0,true);"/>
<input id="Appointment_request_group_Phone" name="Appointment_request_group_Phone" type="text" value="" class="formTextfield_Large" tabindex="5"  />
aladdin229745
Hi Jason,
Thanks again. This sorted some of the problem but not all.
If you enter 11111 111 111 it is fine. But if you enter 11111 111111 or 11111111111 it is not. User can use either method to enter the numbers. It will all mean same. In fact most people will use the last format 11111111111. So what we need to do is somehow disable format validiation but keep the field entry validiation (numeric).
I am sorry I am taking your time but this is the first time I have come accross this kinf of validiation. Although I am in UK, I have filled in several forms belonging to USA websites and did not experience this before. It could be an important issue for people who are using form builder for their websites in the USA and hoping that someone in Europe or other counties can use the form in ease. I think the visitor will be very frustrated and give up filling the form with their details if they cannot enter the phone number or cannot get vaildiation. My telephone number will always fail validiation. If I was filling in a form which I beleive from outside UK 0044 1392 444 XXX. This would have never pass the validiation.
Do you think this should be sorted out within the program itself / or a MOD must be created to implement after? But in my opinion visitors from anywhere on the world should be able to enter their telephone number without difficulty as most forms require a validiation for this. WebAssist must agree that WWW is WORLD WIDE WEB and not just for USA.
aladdin229745
Jason,
I would like to thank you for trying to sort it out for me, but thinking a bit further, I can see the above problem is not only my problem but all form builder users including the websites in the USA. Lets say you have used Webassist to build your online store and used form builder to collect customer information. If the customer cannot enter their telephone number, they will leave the site with frustration and as a result no sales. Customer may not even come back remembereing the experience he/she had.
I am already frustrated because I have spent about 4 hours trying to figure out, wasted your time trying to help me, apart from purchase of the product which doesn't do what I need it to do.
When you set a format, the number entered must match that format.
you can force the number to be entered to match the format you wish to use by turning the character mask on:
var Appointment_request_group_Phone_Spry = new Spry.Widget.ValidationTextField("Appointment_request_group_Phone_Spry", "phone_number", { format:'phone_custom' , pattern:"00000 000 00?", useCharacterMasking:true, validateOn:["blur"]});
really, the problem you are bringing up is a limitation to the Adobe spry phone validation. if you wish to be able to allow phone numbers from any country, you would be better of using numeric validation instead of phone validation.
aladdin229745
Hi Jason,
I think numeric validiation only will be ideal for me. Can you tell me how to set this up by default so anytime when I use form builder it will disregard phone formating but still use the numeric validiation.
