CSS Menu fails
Thread begun 6/29/2010 4:06 am by malcolm230194 | Last modified 6/29/2010 5:57 am by malcolm230194 | 1950 views | 2 replies |
malcolm230194
CSS Menu fails
A functioning vertical menu stopped functioning for no obvious reason. The menu will work in browser preview but not work on a live page. In preview all code is in the html but on live page code is in /CSSMenuWriter however all paths are correct. A horizontal menu on the same page works as expected.
neilo
Hi Malcolm,
Could you provide a link to the live page, please? It will be easier to diagnose your particular problem if we can see the page.
malcolm230194
Solution
Sorry. My cock up. I'd checked and double checked everything so decided to try a spry menu. Same thing happened. The problem was an overflow: hidden in a containing div that hadn't shown up in css styles.
This seems to be a problem with CS5. Changes made in the style panel don't always show in the code and vice versa. Anyway the problem is solved.
