Need help
Thread begun 6/02/2009 9:42 am by coinandbullion379666 | Last modified 6/03/2009 4:15 pm by Ray Borduin | 8019 views | 11 replies |
Need help
Hi
I got the supersuite a while back, basically trying to create something like this
cbcent_TEST_2.htm
but can't figure out what should i do since i am new to this.
Any help or guidance would be appreciated.
thanks
sean
Start by making the page look correct. Then try to add the functionality.
The reality is that it may be difficult to do this without at least a small amount of hand code. Regardless Webassist tools won't help you make a page that looks like that.
You will need to use Dreamweaver Recordsets, Repeat regions, and forms in conjunction with a database in order to create a page that looks like that. Once you have it looking the way you want then you can start worrying about how to add the checked items to the cart.
Need help
Hi
Thanks Ray,
this is just an html page i am still trying to figure out how to setup the database.
Can you suggest as any code.
Regards
sean
idea
Hi Ray
I think this is a good example for further improving eacart suppose you guys can add a template like this.
sean
Try
Hi Ray
As per your suggestions i tried something take a look at this
cbmorg_1.php
this is out of just a simple database
but now say the user checks 10 items then hits add to cart do you think ecart can that?
sean
The next step is to get the checkboxes to filter a recordset. Once you have a recordset filtered with the checked results, then eCart can add all of the products from the recordset to the eCart.
Try
Hi
Thanks Ray
But can you give me a hint as to how do i filter this.
thanks
sean
DataAssist Search will help tremendously when trying to filter a recordset based on the results of a form post. I would start there.
Try
Hi Ray
When filtering i get the variables url parameter, form variable, cookie,session,sever variable,entered value.
I think it should be either form or cookie or can be session too, can you correct me
also there has to be one button for add to cart so its going to be that user can check
multiple items and add at once to checkout.
I am getting there with datassist but a little confused still.
sean
Take it one step at a time.
Don't worry about the add to cart yet. That will be the easy part.
You will be filtering from the results of a form post. All your checkboxes should be within a single form with a single submit button (later to act as the add to cart button, but like I said don't worry about that yet).
I don't think you need cookies or sessions to create your filter it can all be done from the form.
