eCart Add To Cart (Get Contents From Recordset) Behaviour
Thread begun 6/29/2010 12:51 am by Dave Buchholz | Last modified 6/29/2010 12:51 am by Dave Buchholz | 825 views | 0 replies |
Dave BuchholzBeta Tester
I wish that you would add an If Item In Cart Binding to this behaviour as per the standard eCart Add To Cart Bindings Tab (Screen Shots Attached)
I am using this Server Behaviour more and more and I have to manually edit this code:
$eCart1->AddToCart(2, "", $eCart1_itemID, $eCart1_itemName, $eCart1_itemDescription, $eCart1_itemThumbnail, $eCart1_itemWeight, $eCart1_itemQuantity, $eCart1_itemPrice, $eCart1_itemColour, $eCart1_itemCatID, $eCart1_itemSubcatID, $eCart1_itemTypeID, $eCart1_itemGenderID, $eCart1_itemSizeID, $eCart1_itemColourID, $eCart1_itemProdType, $eCart1_itemSize, $eCart1_itemPersonalise);
} while ($row_rsTempOrder = mysql_fetch_assoc($rsTempOrder));
to manage the add to cart behaviour, and this gets overwritten if the server behaviour is opened again in Dreamweaver which is a real pain.
